Vacuum line split at Fuel pressure regulator
SD
Post Tue Jun 20, 2006 10:17 am
The vacuum line on my Fuel pressure regulator has split at the regulator end. It's bodged up with some tape at the moment, but obviously needs replacing.
Can I buy the pipe as a part (sorry realoem blocked at work)? Or will I need to make one?
Ant
Retired Team Member
Retired Team Member
Post Tue Jun 20, 2006 10:21 am
you can buy the part but any vacuum hosing from your local factors is fine dude
SD
Post Tue Jun 20, 2006 10:39 am
Cool - thanks
