My next problem is quite dire and is slowly killing my E30.
There we go a nice dramatic sentence to get your attention
Where the drain hoses for my sunroof meet the sunroof the metal has corroded away so that any water in there just goes straight into the headlining and then drips into the footwells (i'm worried about this rusting the floorpan) i think it is doing the same at the rear drain holes as the back seats are damp.
What can i do about this? Access is quite tight for any intricate work and at the moment i have stick some electrical tape over the holes, punched a hole through the tape a siliconed some tube through the hole to take the water down to the original tubeing. this works for the front but emphasises the rear as water cant escape as freely because the bodge is slightly raised so more water runs backwards.
Sorry to ramble but it should give you the idea, is there any simple way others have cured similar problems?
PS, i can post some photos but i dont know the sizes and whatnot, if anyone can tell me how big i can go it would be realy helpful!!
Chris
