check control oil light
tbmw
Post Tue May 30, 2006 10:21 pm
my engine oil light is staying on on my check control panel, however the oil level is ok, is this a common fault and can anyone tell me the easiest way to sort it?
If it's a case of changing the sensor, where is this positioned and does neone have a part number?
Thanks in advance
A clear conscience is a sign of a bad memory
Post Tue May 30, 2006 11:11 pm
Sensor is in the sump below the altenator, held in place by two nuts and sealed with an O ring. It's hole is just about at the normal oil level, so you may or may not get oil coming out when you remove it.
Over time, sludge builds up inside the cannister and can make the float stick. Cure for this is to flush it several times with petrol.
IIRC, the only time I have had a case of the light staying on permanently, it turned out to be a faulty panel in the roof. Probably a diode, but it just got binned and replaced.
SD
Post Thu Jun 01, 2006 12:31 pm
Mine has just come on as well - after I disconnected the battery (working on clocks). Reconnected battery and light was on. Drove it to work and back yesterday, and by the time I got home I noticed it was out.
Disconnected battery to swap new speedo last night - lo and behold, oil check warning light on test drive.
Coincidence? Or dodgy connection?
Wiggy
Location: San Diego......which in German means a whale's vagina
Post Thu Jun 01, 2006 1:06 pm
Oil Check Light always come on after I disconnect my battery as well. Usually goes out within 100km's of driving.
60% of the time it works........every time !!!
Post Thu Jun 01, 2006 7:09 pm
Wiggy wrote:Oil Check Light always come on after I disconnect my battery as well. Usually goes out within 100km's of driving.
Never come across that one!
