Was polishing a few panels on the car last night (it's starting to look less pink), and was putting some stuff away in the boot.
Noticed a bit of water in the right rear storage compartment, knew it was only a matter of time until I found a leak, so decided to have a poke around. Removed the trim panel in the compartment, and ran my fingers up the back of the inner arch. Aha! A bit of rust - let's see what state it is in - scratch, scratch, crumble, crunch!. Four fingers poking through the arch.
Bugger. So some welding is now added to the list.
The "To Do" list just gets longer
dark_sounds
unlucky dude, i got this problem coming up as well,,, not sure what the source is though, hopeing its less serious!
good luck!
good luck!
pete320i
hi, with a e30 there is always some thing to do, and the list does get larger. but they are fun thats why we own them. good luck with your car,
320i dolphin grey.
