Was polishing a few panels on the car last night (it's starting to look less pink), and was putting some stuff away in the boot.
Noticed a bit of water in the right rear storage compartment, knew it was only a matter of time until I found a leak, so decided to have a poke around. Removed the trim panel in the compartment, and ran my fingers up the back of the inner arch. Aha! A bit of rust - let's see what state it is in - scratch, scratch, crumble, crunch!. Four fingers poking through the arch.
Bugger. So some welding is now added to the list.
The "To Do" list just gets longer
dark_sounds
unlucky dude, i got this problem coming up as well,,, not sure what the source is though, hopeing its less serious!
good luck!
good luck!
