Car was serviced last week and runs fine but whenever I drive her hard briefly, like when overtaking or when i'm p*ssed off the coolant light comes on.
Why is that?? Is the consul lying?
Coolant light on check consol
camcc
1989 325i Convertible
delboy8000
mine does the same mate when heavy cornering,but its the washers fluid light,must be a fault.
Usual cause of this is the float mechanism in the washer bottle partly turned on its side.delboy8000 wrote:,but its the washers fluid light,must be a fault.
Check the connector is on the coolant tank properly.camcc wrote:Car was serviced last week and runs fine but whenever I drive her hard briefly, like when overtaking or when i'm p*ssed off the coolant light comes on.
May be just a failing sensor. Water eventually gets into the centre stem and corrodes the thin wires to the reed switch.
Cheap and easy to replace, but make sure you get the right one. There are two versions and they are a slightly different length. More importantly, they work in opposite ways.
Cyruz
Aye when drifting the washer fluid warning always comes on, I just press check to make it fook off
