320i to a 2.7 alpina......
MOODY
Possibly your 320 ECU can be used with a 2.7 zone chip, if you can't get the right one.
Your 320 gearbox will fit, but is supposed to be weaker than a 325 one.
If you use the 325 box, then you will need a prop as well.
Don't forget to fit a spigot bearing in the end of the auto crank!
