325i clutch Going!! Symptoms..
H35-IAN
Post Tue Apr 11, 2006 2:05 pm
hi guys as u may know ive got a 1986 325i sport mtech one amongst others ,
can anyone tell me wat kinda weird things happends when the clutch starts going on these so far in all the cars ive had ive never had one fail on me!! hehehe but at times it seems to get slightly heavier especially if ive just give it a bootfull"...Anyone?? :cool:
bmw 328i sport e36 :)
m-dtech
Unapproved Trader caution
Post Wed Apr 12, 2006 1:45 am
clutch symptoms would be.
Clutch pedal is higher than normal.
You touch the clutch pedal and revs imediatley go up.
High revs inbetween gearchange.
TheDutch
Post Wed Apr 12, 2006 6:09 pm
m-dtech wrote: High revs inbetween gearchange.
Would this not be casued by poor actuation of the clutch i.e. master/slave cylinders wearing out, not the clutch plate itself. Can you elaborate?
Post Wed Apr 12, 2006 6:16 pm
If the clutch is worn down enough, you will notice it will start to slip occasionally. Inbetween gear changes etc.
The pedal will also firm up quite a bit compared to a good clutch, but you may not notice if this is the only car you drive.
Turbo-Brown
Boost Junkie
Post Wed Apr 12, 2006 6:34 pm
The clutch was down to the rivets on my 325 when I changed it (and the other bits).
It never slipped and the bite point didn't seem to be different to the new clutch, but the pedal was bloody heavy which is pretty symptomatic of knackered clutches it seems.
Post Wed Apr 12, 2006 8:15 pm
they get heavy because the release plate springs have no more movement left in them. After this the next stage is broken release fingers rattling round the bell-housing :lol:
WerkdE30
Post Thu Apr 13, 2006 11:33 am
i have never replaced a pressure plate when doin a bmw clutch.
the most obvious thing is the clutch becomes extremely heavy i was driving a 325i cab today and it took considerable effort to push the clutch in. also when changing quickly u may get a violent change and of course if you abuse it a little dropping the clutch at high revs say between 1st and 2nd it becomes very obvious that it is slipping. if its slipping badly enough you will get a destinct and horrible smell in the cabin possibly smoke too.
H35-IAN
Post Thu Apr 13, 2006 6:06 pm
cheers for all the help there lads to be honest i think its just drift damage lol the cars just done 88k miles it doesnt slip one bit just occasionally pedal gets heavy in time i will prob just change it anyway hey for wat its worth........lol ive got loads to change asap but m8s seem to be letting me down lol anyone up for some overhaul work lol this weekend hehehhe whos got either a good workshop or a set of ramps!! ive got all the parts and the tea and sugar n milk lol :cool: :wink:
Post Fri Apr 14, 2006 6:51 pm
Heres a clutch I changed today, the release bearing had been whining for a few months and eventually seized and fell apart causing this to happen
Post Fri Apr 14, 2006 8:55 pm
Edit :mad:
