stereo keeps resetting
e30-320i
Mon Apr 10, 2006 1:26 pm
i have a strange problem with my car if i turn the key to the 1st click so the dash lights up and then start the car my stereo will reset itself losing all the settings yet if i put the key in and turn it all the way immediatly it is fine can anyone shed any light on what the problem could be i have no idea
89 325i touring
N4SBM
Mon Apr 10, 2006 3:58 pm
i think u may need to wire the sistem direct so it wont loose the memory..
SilverShadow
Hartge Crew
Tue Apr 11, 2006 10:01 am
Most car stereos there are 2 mains, 1 is wired up to the ignition and the other is wired up directly to the battery.
The ignition wire is for powering up the stereo when you start the car, so you can't leave the stereo on while the car is off, Otherwise the battery will die.
The main that is connected directly to the battery is for the memory of the stereo ( EQ setup, radio stations etc)
However you can have both mains connected to either directly to the battery or directly to the ignition, but if both wires are connected to the ignition you will keep loosing you memory. Directly to the battery will keep all the settings on the stereo.
I hope this clarifies things!
e30-320i
Tue Apr 11, 2006 12:30 pm
the stereo always keeps it memory while the car is switched off it only looses it if i turn the ignition 1 click and then start it from there if i put the key in and turn it all the way it is fine
89 325i touring
