Basically is this right do they come as a three piece for the later sports or have i been sent the wrong exhaust?
Have i got the right scorpion exhaust??
wilkos
Got home tonight and found my Scorpion system waiting for me
so I opened it up and found it to be a three piece system and the original system on my '91 sport is a two piece!,which i told them over the phone when i ordered it!!
I'd be grateful if someone out there can put me right, before i phone them up and give 'em a round of fcuk's
cheers. Si
no it's fine, 3 piece and 2 piece fit on 325i's. No problems my man!
wilkos
Cheers for that dude so should have no probs even tho the old system was a two piece will the mounts be in the right place etc?
kam-325i
The mounts should be in the same place...
One just before the front box
One just before the Rear beam
Two for the back box
oze30
erm.. slight problem.. You're going to have to go to a exhaust shop and cut the rear of the two piece in order to fit the 3 piece rear. The 2 piece is rear box and pipes to a fl;ange just after the middle box... the front section is from the downpipes back to the middle box, then the flange.
You'll need to have a looksie to see if this is possible, else.. i dunno what to do!
HTH
HTH
