found a 325 for sale but tappetts are a bit noisy engine runs well otherwise. smooth no smoke etc.
how much would the tappetts cost to do?
what else could be wrong with the engine if it sounds like that?
tappetts...how much?
Andy325i
An hours labour + a rocker cover gasket (about Ԛ£20 from ECP) should cover it unless the lobes are worn or cam. Check the spray bar is working correctly as well.
Andy
Andy
onslow
so about Ԛ£80 with parts labour and vat...
sounds reasonable cheers for the reply!
is also has a chip sourced from here and an enlarged throttle body. will this make much of a difference to the performance or just increase the fuel bills?
JAMZ
Both..
Performance Gain & a noticible fuel diffrence..
like said above make sure its not the Cam thats porked..a symton of noisy tappets..could just need an adjustment though.
oze30
how to tell if cam is cactus?
onslow
so worse case scenario and the cam is cooked what do you estimate the repair bill would be?
the rest of the car is minty minty so it may be worth the expense provided we are not talking thousands!?!
DazzyA
I just adjusted my valves thanks to the tech article, very easy and the difference was amazing, If you can use a spanner you an do it yourself no worries. Don't forget to take the spanner off the crank bolt, that was close!!
Pass me the spanner
Andy325i
If the cam is knackered consider putting a performance cam in
Andy
Andy
oze30
how do you tell if it is knackered?
Andy325i
visual inspection? Not sure TBH, M40 cams often wear but look like new
Andy
Andy
johnono
if u can see tracking or scoring on the cam either side of the lobe then the cam may be ka-put, and also may have a oil bar / pressure prob
oil pump, new cam, oil spray bar flush out, rocker cover gasket, and check if rocker lobes arnԚ´t damaged ;)
but thats if its totally mash, which it wont be so dont worry fella, but be aware of all the parts connected to the prob as a next potential prob
christ, talk about the voice of doom
