This is the next job on the car.
I’ve had the slave cylinder off before, which is not easy grovelling under the car, but never the master.
There’s a good write-up on the Wiki re the slave, but no details at all on doing the master cylinder. I wondered why!
Does anyone have a post on it to make life easier.
Next job.
minesapint
minesapint
Sorry I should have put this in technical help.
There's a few guides on YouTube covering this.
minesapint
Yes I’m sure.
Looking in Technical help there’s a post made into a sticky from Paultv written in Aug 2019, with advice & tips , but no pictures, I like pictures they save so many words.
I think the Wiki needs more info on changing the master clutch cylinder, in the style it does for the slave cylinder, which is an excellent article. I notice that the great Mr Mooore & others were involved so it’s guaranteed to be perfect.
For the master cylinder I would strongly recommend buying a new length of hose and the plastic fitting that connects the two together
minesapint
Do you mean parts 07 & 08 in diagram?
If so thanks bud…..all tips gratefully accepted.
Any more?
Any more?
minesapint
Not a particularly difficult job just very awkward working in tight area around the pedal set.
minesapint
Working on the slave much more difficult, as having no clutch meant I couldn’t drive onto the car ramps,so struggled with little space.
Anyway done now ……..they’ll see me out!
