Overheating/damp LH carpet.
jmec
Post Tue Feb 25, 2025 9:03 pm
Hi chaps and chapesses. I'm thinking leaking heater matrix or controller for the above indications. Any advice for access and necessary removal/refitting of possible offenders will be gratefully received. Thanks in advance.
Post Wed Feb 26, 2025 2:22 pm
jmec
Post Wed Feb 26, 2025 8:23 pm
Thank you Speedtouch. I'll check the O ring where the valve tube fits up to the matrix. Is there also an O ring where the electrical valve fits to the tube?
Post Wed Feb 26, 2025 9:26 pm
I suspect there is more than one, since the Wiki states: "The heater valve connects the matrix to the stub pipes, and its joints and O-rings can break down over time."
Here's more to check out:
jmec
Post Thu Feb 27, 2025 3:12 pm
Thanks Speedtouch. Great leads and advice. Had a fun morning getting the valve off. Stripped it down and the diaphragm is torn to bits. So a firm answer to the problem. Just off to sell my first born to afford a replacement!
Post Thu Feb 27, 2025 3:59 pm
Cool, glad the links were of some help.
