Blocked fuel return line inside tank
Onure30
Post Mon Jan 13, 2025 8:25 am
My return line inside my fuel tank is blocked,
Anyone know a good way to unblock it?
Ive sprayed it up with WD40 and let it soak for days and air pump to (200psi) and still not budging.
Post Tue Jan 14, 2025 3:44 pm
Perhaps try 'dyno-rodding' it with a length of wire or bowden cable, perhaps? Also try using a degreaser such as Gunk rather than WD40....
This thread may offer some tips:
https://www.bimmerforums.com/forum/show ... rn-Blocked
Onure30
Post Wed Jan 15, 2025 9:02 am
I need a new tank,
I cut open the fuel tank and removed the pipe and unblocked it, i then filled the tank up with water and the siphon is still not working. Something is messed up inside the pipe
Im after a used or new fuel tank..
E30Derbyshire
Post Thu Jan 16, 2025 4:36 pm
Fuel tanks are still available new from BMW, but they ain’t cheap!
Onure30
Post Fri Jan 17, 2025 1:22 pm
Got a used 55l tank and fuel gauge to go with it,
The 63l tanks seem unreliable, 55l runs the transfer pipe outside the tank.
