320 to 325
bellgtti
Post Fri Feb 10, 2006 6:53 pm
querying how hard its actually to do i have the block gearbox and ecu and air fuel senser wat else would i need ????
stevetigger
Post Fri Feb 10, 2006 7:43 pm
straight swap, you can keep your prop and diff and some other stuff
Go on :thumb:
bellgtti
Post Fri Feb 10, 2006 7:55 pm
well its either swap the engine or pay out for the rocker to be fixed can always sell the 320 engine to someone wanting a 316/318 upgrade
stevetigger
Post Fri Feb 10, 2006 7:56 pm
yes lots of people want a 2.0ltr head for a 2.7 conversion
bellgtti
Post Fri Feb 10, 2006 8:21 pm
only thing im gonna need is a clutch then i spose
stevetigger
Post Fri Feb 10, 2006 8:25 pm
bellgtti wrote:only thing im gonna need is a clutch then i spose
Why would you need a clutch>???
Post Fri Feb 10, 2006 9:28 pm
bellgtti wrote:well its either swap the engine or pay out for the rocker to be fixed can always sell the 320 engine to someone wanting a 316/318 upgrade
316/318 to 320 is not considered to be much of an upgrade.
Why would you want to change an engine just for a broken rocker?
It's easy enough to change - get stuck in!
HartgeH27
Post Fri Feb 10, 2006 10:48 pm
Agreed !!!!
Dont know of anyone wanting to go the 320 upgrade, normally its right up to the 2.5.
As Brian says fix it !!!!! Best and most economical option.
stevetigger
Post Fri Feb 10, 2006 11:31 pm
I think this is why he wants to change rather than repair
Click this to see
bellgtti
Post Sat Feb 11, 2006 12:17 am
been quoted 100 pound for the rocker but not with the cambelt being replaced :( or i have a 325 sport engine which could go in instead of the 320 ii dunno not sure wat to do would anyone be intereted in a 32o engine or not really?????????
Templ8e30
Post Sat Feb 11, 2006 12:20 am
You'd struggle to shift a 320i engine, even a good low miler isn't very desirable.
However the head is of use in a budget 2.7 conversion, I'd whip the head off and flog that on here then take the rest down to the scrap metal merchant.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
N4SBM
Post Wed Feb 15, 2006 10:57 am
bellgtti wrote:been quoted 100 pound for the rocker but not with the cambelt being replaced :( or i have a 325 sport engine which could go in instead of the 320 ii dunno not sure wat to do would anyone be intereted in a 32o engine or not really?????????
I WOULD BE INTERESTED IN M20, HOW MUCH, LOCATION, MILEAGE, CONDITION. PM ME IF STILL AVAILABLE.
THANKS
Geeman
Post Wed Feb 15, 2006 11:11 am
If you're changing the gearbox as well as the engine from a 320i to a 325i, you'll need to change the prop as well. I've been reliably informed that the 325 gearbox has a longer casing, so as a result, the 320 prop will not fit.
HTH
Giles.
