Obc 13 button bc stalk not working
Gaffasgaff
Post Sat Nov 04, 2023 3:05 pm
Hello guys. Struggling to work out why my indicator bc button isn't working. This has stopped 10 years ago when I had my Clifford alarm professionally installed. It never really bothered me much as the car spent most its life in storage. I finally bought a house with a garage where i can now tinker wife my pride and joy . I have done a continuity test on the pins on the indicator switch and the bc button is making contact. So I have notice there is a blue single pin connector and nothing is going to it . I have spent a good half hour searching for a wiring around that area that would plug into that thinking it's come off while he did the alarm and i cannot find anything. Am i on the right track here is something suppose to connect to this inorder for it to work . If so where dose the wire come from. Any help would be much appreciated
BenHar
Post Sat Nov 04, 2023 5:35 pm
Does this page from the wiki help?
https://www.e30zone.net/e30wiki/images/ ... mputer.pdf
Ben
Gaffasgaff
Post Sat Nov 04, 2023 7:27 pm
BenHar wrote: ↑
Ben
Thank you Ben.
I cannot work it out :mad:
Gaffasgaff
Post Sun Nov 05, 2023 3:25 pm
8O Any ideas any one
Gaffasgaff
Post Mon Nov 06, 2023 8:07 am
I have the 13 button obc. I can't find a cable to fit this .
biffer
Post Mon Nov 06, 2023 10:05 pm
On my car,the single cable you are looking for hangs down from where the main OBC loom loops over the top of the instrument-cluster
Gaffasgaff
Post Tue Nov 07, 2023 8:31 am
biffer wrote: ↑
Cheers biffer
I have searched around and cannot see it at all .
I got round looking and understanding the wiring diagram and I beleave it's coming from pin 4 of the obc . So I will trace it from there and hopfully will see if I can locate it . Weekend job now . Thank u
biffer
Post Tue Nov 07, 2023 3:00 pm
Mine is a single thin, black wire, a few inches long,with the blue connector on the end, and it hangs down either just to the left of the cluster,or behind it-can't remember which
Gaffasgaff
Post Wed Nov 08, 2023 4:49 am
biffer wrote: ↑
Fixed!!!!!!
Finally found that wire tucked behind the centre console. God knows how it's got there.
Cheers. :D
Post Wed Nov 08, 2023 5:12 pm
Gaffasgaff wrote: ↑
biffer wrote: ↑
Fixed!!!!!!
Cheers. :D
:clap: :clap: :clap: :clap: :clap: :banana: :banana: :banana: :banana: :banana:
