Help - identify what steering rack I have?
ocde30
Post Fri Aug 18, 2023 1:48 pm
Hi, I need to change the steering rack boots on my 1991 318i.
On closer inspection and research in the service history it seems the original rack was replaced by a “re manufactured” item in 2008. I’m not sure what this rack is and so it is difficult order the correct parts.
Please could anybody identify what I have from the stamped code 7832 501 183
and the attached picture. I have other pictures but can't seem to be able to upload more than one anymore.
ocde30
Post Fri Aug 18, 2023 1:50 pm
Post Fri Aug 18, 2023 6:43 pm
Not sure about the rack but I will look in to the posting issue for you.
You OK mate ??? :clap: :clap: :clap:
Post Fri Aug 18, 2023 7:32 pm
Its just the usual late style E30 power steering rack
ocde30
Post Sat Aug 19, 2023 3:49 pm
Thanks guys,
All well thanks Mart, bobbing along.
Thanks Dan I thought it looked fairly stock as well but it's just that when I put chassis number into various suppliers it comes up with a boot that has a wider end on the control arm and not the thin one like it has now.
Attached is the sort of boot that crops up with my details.
What I will probably have to do is go to a local steering rack specialist and let them have a look rather than ordering the wrong part online.
Thanks for you help.
Post Sat Aug 19, 2023 8:01 pm
They will have fitted a generic chinese boot when it was recon'd
Hence why it hasnt lasted, the outer end should be clamped around a rubber shaped like a large washer, and not to the tie rod itself
If you need some I can put some in the post, I remove them when doing E46 rack conversions and usualy have a few floating around the workshop
ocde30
Post Mon Aug 21, 2023 3:12 pm
Thanks Dan, I've sent you a PM.
Cheers,
Trevor
Post Mon Aug 21, 2023 7:55 pm
Got it, im posting some parcels tomorrow so aim to send you a pair at the same time 8)
