Power Point in Glove Box - Plug C302 Connector Part Number
TurtleDesignTech
Post Sat Apr 15, 2023 3:25 pm
Looking to connect up an additional cigarette lighter/USB charging point in the glove box.
Ideally would like to pull power from plug C302.
Has anyone done this before? If so, are the parts still available to create a OEM style connector?
flybynite
Post Sat Apr 15, 2023 5:52 pm
I have had quite a few pins and plugs for the E30/36/46 from Cotswolds over last few years, It can be trial and error on RealOem but I'm sure if you give Jon a shout at Cotswolds he will have a better look on his system for the right shape plug :thumb:
TurtleDesignTech
Post Sun Apr 16, 2023 7:46 pm
Good idea. Have contacted Jon. Will post the part numbers here if we manage to find them.
Contours
Post Tue Apr 18, 2023 1:16 pm
They are of a female type bullet connecter so would imagine an electrical outfit should be able to supply them. You could power the unit off terminal H on the C302 which would be for an amp where fitted and is controlled by fuse 27 which also controls the central locking circuit. (30amp)
