E30 M3 Fuel Filler bodywork panel
M3Tarmac
Mon Oct 04, 2021 8:58 pm
Hi All,
I have a 1988 E30 M3 which is having some bodywork issues being addresssed. Inside the fuel filler flap, the lip around the access hole to the fuel cap was corroded. It is a very fiddly job to repair, so I'm looking for a panel section that can be bought. Is this a unique body feature to the M3, or can it be got from any E30 model?
I also need a part code for the rubber boot between this lip and the fuel tank neck, it was perished. I ordered one but it is a donut, not the boot that is needed. Any tips?
1988 E30 M3
Tue Oct 05, 2021 5:01 pm
Welcome to the zone mate and have a talk to the guy`s at Cotswold on here, they are VERY good.
Pic of the M3 are an option but....................do it now !!!!
LOL.
HenryM3
Tue Oct 05, 2021 7:42 pm
51 71 1 884 358 I think that is the part you need, do double check though.
M3Tarmac
Wed Oct 20, 2021 9:59 pm
Thanks Henry, I think you're right.
Any ideas on the body panel part? It's the recessed aread under the filler flap - the larger end of that rubber seal fits onto it. That's the area that was rusted, and is covered in paint on my photo to keep it from getting worse while I sorted a new part. We could make a repair piece, but it would be a lot easier to buy one...
Mart - I will get some photos when the car is back out of the workshop!
1988 E30 M3
Thu Oct 21, 2021 4:55 pm
:clap: :clap: :clap: :clap:
kundiboy
Sat Oct 30, 2021 12:47 pm
You will be able to use the fuel filler recessed piece from a standard e30. Just need to cut out the old section and weld in the replacement. Not a big job for a decent body shop.
1988 Diamond Schwartz E30 M3
M3Tarmac
Sat Oct 30, 2021 12:51 pm
Perfect, thanks kundiboy - "any E30" is the key info!
1988 E30 M3
haxelfebl
Mon Nov 08, 2021 8:14 pm
Hi All,
Anyone able to shed light on the Throttle screws on each throttle body / intake on the E30 M3 S14 engine? Part # 13541402567.Tweakbox Appvalley https://vlc.onl
