E10 fuel
e30veg
Post Wed Sep 01, 2021 4:11 am
Is it safe to use E10 grade fuel in m20 engine?
flybynite
Post Wed Sep 01, 2021 8:40 am
If you have replaced your fuel pipes than should not be a problem. Then again if you are still using 30 year old fuel pipes it is not really safe to any grade of petrol.
e30veg
Post Wed Sep 01, 2021 9:33 am
Post Wed Sep 01, 2021 12:43 pm
Sainsburys near me have a "super" grade 97 octane still E5 and I am using that.
Non of the other supermarkets near me sell E5 .
e30veg
Post Wed Sep 01, 2021 1:44 pm
Cheers mart, good to know that we can use super grade fuel
rix313
Post Wed Sep 01, 2021 10:10 pm
Our local Tesco has 99 but the Sainsbury’s hasn’t got super. I’ve been meaning to go in and see if it’s something they can do as they have 6 pumps there.
Post Thu Sep 02, 2021 8:23 am
I use Esso Supreme+99 which in my area has no ethanol but it does cost more.
BHadley
Post Thu Sep 02, 2021 2:17 pm
According to a “is e10 safe list for xx car” all Bmw engines are fine.
onthames
Post Thu Sep 02, 2021 2:30 pm
It's not the engine it's the hoses
Post Thu Sep 02, 2021 3:02 pm
I have also heard that the carb cars can be effected, to what degree I`m not sure, but for the small amount of price difference E5 it is for me too.
My E46 325 responds better and I have a 15% -20% gain in MPG too when I use Shell V-Tech or higher octane fuels.
Post Thu Sep 02, 2021 3:33 pm
With carb engine the float if it has any soldered joins then yes. Also some plastic floats as well as I have read somewhere. With carb engines they usually have mechanical fuel pumps so diaphragms possibly .
I am not sure about the E10 checker site as most of the BMWs are fuel injected with only a handful of carb cars around.
flybynite
Post Thu Sep 02, 2021 3:52 pm
Yes, unless it is a carb engine, (and then AFAIK it depends on which carb) the injected ones should be fine.
As I said above putting any petrol into 30 year old pipes is asking for an engine fire, E10, E5 or E0 will burn just as well
parkin10
Post Thu Sep 23, 2021 9:49 pm
Been setting fire to e10 fuel in my e30 m20b25 so far its been fine
My e30 not pristine so I am not too worried but I am keeping an eye out for trouble
