[SOLVED] Cluster and dashboard illumination stopped working
twenty
Post Thu Apr 29, 2021 11:49 pm
Hi,
I have a strange problem. When I turn on the city lights or headlights, the OBC, cluster or dashboard illumination lights doesn’t come on.
When off, the OBC backlight works fine. The cluster works fine too regardless.
I checked fuse 21 and it’s fine.
I should mention that the OBC led has the usual bleed for a while now but this suddenly started a few days ago.
Cloggy Saint
Post Fri Apr 30, 2021 12:22 am
Obvious question, but has the dash illumination knob been turned?
twenty
Post Fri Apr 30, 2021 12:31 am
Cloggy Saint wrote: ↑
Yes!
Cloggy Saint
Post Fri Apr 30, 2021 11:20 am
Yes it's been turned to minimum or yes it's turned up full? :?
twenty
Post Fri Apr 30, 2021 2:00 pm
Very funny!
Post Fri Apr 30, 2021 2:12 pm
twenty wrote: ↑
Very funny!
I dont think he was being funny, this has been a problem before for some poor guy on the forum.
Cloggy Saint
Post Fri Apr 30, 2021 2:38 pm
No humour/humiliation intended! It's sorted?
twenty
Post Fri Apr 30, 2021 3:47 pm
No. Obviously.
twenty
Post Sun May 09, 2021 8:28 pm
Quick update. After checking wiring fuses etc. and getting a helpful tip-off that the headlight switch could be a problem, I’ve narrowed it down to a worn rheostat in the headlight switch.
