Hi,
I have a strange problem. When I turn on the city lights or headlights, the OBC, cluster or dashboard illumination lights doesn’t come on.
When off, the OBC backlight works fine. The cluster works fine too regardless.
I checked fuse 21 and it’s fine.
I should mention that the OBC led has the usual bleed for a while now but this suddenly started a few days ago.
[SOLVED] Cluster and dashboard illumination stopped working
twenty
Cloggy Saint
twenty
Yes!Cloggy Saint wrote: ↑Fri Apr 30, 2021 12:22 amObvious question, but has the dash illumination knob been turned?
Cloggy Saint
twenty
Very funny!Cloggy Saint wrote: ↑Fri Apr 30, 2021 11:20 amYes it's been turned to minimum or yes it's turned up full?![]()
I dont think he was being funny, this has been a problem before for some poor guy on the forum.twenty wrote: ↑Fri Apr 30, 2021 2:00 pmVery funny!Cloggy Saint wrote: ↑Fri Apr 30, 2021 11:20 amYes it's been turned to minimum or yes it's turned up full?![]()
Cloggy Saint
twenty
No. Obviously.
twenty
Quick update. After checking wiring fuses etc. and getting a helpful tip-off that the headlight switch could be a problem, I’ve narrowed it down to a worn rheostat in the headlight switch.
