Hi everyone got problems with fuse 21 blowing anybody got a wiring diagram so I can trace it without cutting all loom to bit pls??
Thanks Matt
318is 1991 2door
Fuse 21
Wiring diagrams here: http://www.autolib.diakom.ru/CAR/BMW/ Use '89 325i.
The most likely cause of your problem (assuming your car is RH drive) is either the glove box light/switch assembly is falling apart, or has been left with no lamp in it.
Towers66
Thanks for tip it was the glovebox switch
Towers66
Itβs started blowing again
and thatβs with global switch removed any more ideas pls?
and thatβs with global switch removed any more ideas pls?-
Towers66
Think I got it pass side roof interior light shorting out
