Hi everyone got problems with fuse 21 blowing anybody got a wiring diagram so I can trace it without cutting all loom to bit pls??
Thanks Matt
318is 1991 2door
Fuse 21
- Brianmoooore
Wiring diagrams here: http://www.autolib.diakom.ru/CAR/BMW/ Use '89 325i.
The most likely cause of your problem (assuming your car is RH drive) is either the glove box light/switch assembly is falling apart, or has been left with no lamp in it.
- Brianmoooore
and thatโs with global switch removed any more ideas pls?
