E30 m60 swap cranking lovely but no fuel
e30-EVN
Post Sat Oct 03, 2020 7:21 pm
Hi guys. So this is bugging me now because I've had the car running a couple times now with no problems
But I've gone to fire it up today and I cant get her to run.
No fuel in the lines and the fuel pump is not prining on the key
I've not changed anything since the last time I had it running which is what's so bizarre.
Any help would be gratefully received
e30-EVN
Post Sat Oct 03, 2020 8:05 pm
I've just been thinking and the only thing different to the last time it ran is an upgrade chip that was fitted in the ecu
Could this be causing the problem of not telling my fuel pump to prime?
Tested the fuel pump fuse (no 11) and it's dead. No power to fuel pump fuse
Post Sat Oct 03, 2020 9:08 pm
Check to see if you have sparks.
e30-EVN
Post Sat Oct 03, 2020 10:05 pm
I'll check this tommorow mate.
As a matter of ruling out, I've opened up the ecu and checked I had fitted the chip correctly, which I had
But I've refit the original chip now so everything is exactly as it was before... a friend says if the chip is bad (and hes seen it before), the ecu wont send the signal to prime the pump?
e30-EVN
Post Sun Oct 04, 2020 2:52 pm
Hi Brian. Fuse 11 is showing as earth even with ignition on and I have no power at the fuel pump plug
Post Sun Oct 04, 2020 10:20 pm
You still haven't said if you have sparks at the plugs.
e30-EVN
Post Mon Oct 05, 2020 10:51 am
Hi brian. I do indeed have spark. Its run this morning all be it with touch if fire drama I had to quickly attend to 8O
I put live from battery to the pump and it ran. So I primed it, then turned the key and bang! She fired up
I suspect to much fuel in the cylinders though as i primed it manually because it caught fire 8O
But it's all good, shes still in one piece lol
So a relief that the ecu is fine, sparks are fine, so I'm narrowed down to no live getting to the fuel pump mate
I dont really want to fire it up again until my fabricator does the manifolds and exhaust next week but atleast I know its running and nothing serious
What would you suggest now mate? As I can still get the pump power issue sorted. Being an e34 engine the pump primes on the ignition so I'll know its solved without having to "FIRE" it up again
Thanks for your help
Post Mon Oct 05, 2020 7:27 pm
Pull out the fuel pump relay, connect a 12 volt lamp between pins 85 and 86 of the relay's socket, then crank the engine. Does the lamp light?
e30-EVN
Post Tue Oct 06, 2020 10:56 am
I will try this when the car comes back from the fabricator now Brian as I dont want a repeat of yesterday 8O
Post Tue Oct 06, 2020 2:10 pm
Cranking is sufficient. It won't start if you don't run the fuel pump.
