Bill Mc 1989 E30
BillMc
Post Thu Sep 03, 2020 3:59 pm
My speedo has stopped working, the mileage and trip meters are both working could the speedo sensor or the wiring connector still be at fault
flybynite
Post Thu Sep 03, 2020 4:22 pm
This thread:
viewtopic.php?t=280053
Has a good discussion about speedo diagnosis
BillMc
Post Fri Sep 04, 2020 10:13 am
Have you any ideas on diagnosis
flybynite
Post Fri Sep 04, 2020 12:09 pm
Did you read that thread?
Personally I would
Check the wires for obvious breaks around the diff
Check the diff output signal, first at the diff then at the back of the dash.
If the signal is getting to the plug at the back of the dash OK then check the instrument cluster for solder issues
Post Fri Sep 04, 2020 3:03 pm
If the odometer and trip are still working, the problem is confined to part of the speedo assembly itself. Nothing wrong with the diff. sender, the plug or the wiring.
minesapint
Post Fri Sep 04, 2020 10:50 pm
As Brian said..................now take out the instrument cluster
BillMc
Post Sat Sep 05, 2020 11:22 am
Thanks guys for the help
