Hi everyone,
Just got myself a mishimoto radiator for my 88 325i and the thing doesn’t fit. It’s way too wide and it won’t sit in the factory grooves at the bottom. I emailed them to ask if I had ordered the wrong part and they said it’s for the US spec car.
Don’t suppose anyone has fitted one of these or would recommend another brand. Looking at slapping a turbo on soon so need to get the cooling sorted.
I do have pictures if anyone needs to see
Mishimoto radiator doesn’t fit!
The clip in brackets that the bottom of the radiator sits in come in various widths, and there will be a combination that fits your radiator.
Someone might be able to help if you measure the mismatch and give the dimensions of the brackets you have.
A quick look at the ETK, suggests that you might need a 10mm RH bracket instead of your existing 120mm one?
maggspower
- Turbo Farmer Tractor Driver
You need 2 RH plastic brackets one for each side.
Contact: theengineshedonline@gmail.com
flybynite
Blimey, everyone coming out of the woodwork now
maggspower
Just checked, my first post in almost 3 years
BristolE30
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
Tricksmith7
I've just had the 2 radiators out and a ruler and its about 11cm difference between the 2 brackets so i will get them ordered when my local stealer opens back up.Brianmoooore wrote: ↑Sun May 10, 2020 10:27 amThe clip in brackets that the bottom of the radiator sits in come in various widths, and there will be a combination that fits your radiator.
Are they simply clip off and clip back on again?
maggspower
If I remember there is a barb that you pinch together and a locating peg and slot.
That's 2 posts now
See you in 2023. We'll all be living, working and sleeping in Zorb balls by then I expect
That's 2 posts now
Tricksmith7
Cheers buddy! I’m only 21 and have only owned my mtec 2 325i for 6 months but I can see your well known on here and have come on just to help me out ;)maggspower wrote: ↑Sun May 10, 2020 6:48 pmIf I remember there is a barb that you pinch together and a locating peg and slot.
That's 2 posts nowSee you in 2023. We'll all be living, working and sleeping in Zorb balls by then I expect
maggspower
PM me your address I'll send you the mount you need.Tricksmith7 wrote: ↑Sun May 10, 2020 7:21 pmCheers buddy! I’m only 21 and have only owned my mtec 2 325i for 6 months but I can see your well known on here and have come on just to help me out ;)maggspower wrote: ↑Sun May 10, 2020 6:48 pmIf I remember there is a barb that you pinch together and a locating peg and slot.
