I’ve had an issue for the last few years that is not major but it is annoying because I can’t find the cause.
When driving off from cold the car suddenly jerks and engine seizes for a split second. It’s more than a standard cut out as if I switched the ignition off for a split second, it’s as if the engine actually jams.
It started after I cleaned and serviced the injectors a few years ago. I’ve replace the fuel filter. No idea what it is. I’m assuming a full leak somewhere but I don't smell fuel.
Any advice is welcome!
Thanks guys.
Temporary cutout approx 30 seconds after driving off.
Doobit
E30 325i Cabriolet Alpinweiß chromie
F12 640d
G11 730d
F12 640d
G11 730d
Is this 'cut out' indicated by the tacho needle?
paultv
Mine did this...but at random times - usually when cold.
I cleaned the AFM track and moved the wiper a little and it was better - but the fault showed up again and became really bad - I replaced the entire AFM and it's never done it since.
It feels like a half second with the ignition off - really horrible if you're accellerating hard in second!
But first check your AFM plug and socket - clean? connections all good?
Paul
Paul
Doobit
Thanks Brian, think the tacho needle drops if I recall correctly.
F12 640d
G11 730d
F12 640d
G11 730d
Doobit
Thanks Paul I’ve not looked at AFM it’s usually accelerating in 2nd 200m down the road and it’s like someone’s hit the break...sounds a lot like what you describe.paultv wrote: ↑Tue Apr 28, 2020 10:19 amMine did this...but at random times - usually when cold.
Paul![]()
F12 640d
G11 730d
F12 640d
G11 730d
Unfortunately, you've given two condradicting aswers in the last two posts.
If the tacho. drops out, then it indicates an electrical fault to the ignition control circuits, such as a crank position sensor beginning to fail, or a dodgy DME relay.
An AFM fault would give a problem with the fuel injection side of things (either too much or too little fuel), and wouldn't affect the tacho. at all.
Doobit
Thanks Brian, I'll try it today and confirm what is the case, I appreciate your knowledge and expertise.Brianmoooore wrote: ↑Fri May 01, 2020 10:59 amUnfortunately, you've given two condradicting aswers in the last two posts.
F12 640d
G11 730d
F12 640d
G11 730d
