Temporary cutout approx 30 seconds after driving off.
Doobit
Post Sat Apr 25, 2020 6:42 pm
I’ve had an issue for the last few years that is not major but it is annoying because I can’t find the cause.
When driving off from cold the car suddenly jerks and engine seizes for a split second. It’s more than a standard cut out as if I switched the ignition off for a split second, it’s as if the engine actually jams.
It started after I cleaned and serviced the injectors a few years ago. I’ve replace the fuel filter. No idea what it is. I’m assuming a full leak somewhere but I don't smell fuel.
Any advice is welcome!
Thanks guys.
E30 325i Cabriolet Alpinweiß chromie
F12 640d
G11 730d
Post Sat Apr 25, 2020 8:59 pm
Is this 'cut out' indicated by the tacho needle?
paultv
Post Tue Apr 28, 2020 10:19 am
Mine did this...but at random times - usually when cold.
I cleaned the AFM track and moved the wiper a little and it was better - but the fault showed up again and became really bad - I replaced the entire AFM and it's never done it since.
It feels like a half second with the ignition off - really horrible if you're accellerating hard in second!
But first check your AFM plug and socket - clean? connections all good?
Paul :-)
Doobit
Post Fri May 01, 2020 12:33 am
Thanks Brian, think the tacho needle drops if I recall correctly.
F12 640d
G11 730d
Doobit
Post Fri May 01, 2020 12:36 am
Paul :-)
Thanks Paul I’ve not looked at AFM it’s usually accelerating in 2nd 200m down the road and it’s like someone’s hit the break...sounds a lot like what you describe.
F12 640d
G11 730d
Post Fri May 01, 2020 10:59 am
Unfortunately, you've given two condradicting aswers in the last two posts.
If the tacho. drops out, then it indicates an electrical fault to the ignition control circuits, such as a crank position sensor beginning to fail, or a dodgy DME relay.
An AFM fault would give a problem with the fuel injection side of things (either too much or too little fuel), and wouldn't affect the tacho. at all.
Doobit
Post Fri May 01, 2020 1:53 pm
Thanks Brian, I'll try it today and confirm what is the case, I appreciate your knowledge and expertise.
F12 640d
G11 730d
