No power reaching window motor
ChrisHC
- E30Zone Contributor
My driver's side window motor stopped working, it appears to be receiving no power. It is not the fuse as the passenger side still works, it is not the switch, because I tried swapping over the switches, where should I be looking next? Perhaps the plug and socket on the A pillar and door?
BenHar
You've answered your own question.
Yes, check and clean the A pillar plug. You can check that the power is reaching the plug at the same time.
Ben
Ben
rix313
Have you removed the door card and checked at the motor?? I recently had an issue with mine. After looking into it, power got to the motor but it seemed to be jammed up. I loosened two of the T25 Torx screws that are accessible and tired again and it went up and down fine. I put some grease on the runners and re-tightened the bolts and it was fine again.
ChrisHC
Yes, I unplugged the motor and checked the male plug from the door pillar, no power.rix313 wrote: ↑Sun Dec 01, 2019 5:26 pmHave you removed the door card and checked at the motor?? I recently had an issue with mine. After looking into it, power got to the motor but it seemed to be jammed up. I loosened two of the T25 Torx screws that are accessible and tired again and it went up and down fine. I put some grease on the runners and re-tightened the bolts and it was fine again.
ChrisHC
Thanks Ben, do you happen to know which pins are for the window? Later - it's OK I found that in the wiki, although it is not entirely clear from the drawing which pin is number 13
BenHar
https://bimmertips.com/bmw-e30-wiring-d ... -download/
Find your car and download.
Look in "Connector views".
Ben
