I’ve had a look through the wiki’s and don’t think I can find the answer for this.
But.... are the m50’s basically the same block and head?
I’m looking to build a forged m50 turbo lump, rods and pistons with possibly cams and valves too... but the m50b25 engines seem sparse and more expensive to buy than a m50b20 for example.
So due to the fact that a lot of the internals will be thrown away anyway, Can the m50b20 be stripped and bored to 84mm with the correct length rods... thus essentially creating a m50b25?
Or are there significant differences between the two blocks or heads that would limit the usage? I know the inlet manifold and some ancillaries may be different. But those can all be sorted separately.
Any advice would be great.
