M50 block/head differences.
Flaffy1991
Post Thu Aug 29, 2019 11:21 am
Hello chaps.
I’ve had a look through the wiki’s and don’t think I can find the answer for this.
But.... are the m50’s basically the same block and head?
I’m looking to build a forged m50 turbo lump, rods and pistons with possibly cams and valves too... but the m50b25 engines seem sparse and more expensive to buy than a m50b20 for example.
So due to the fact that a lot of the internals will be thrown away anyway, Can the m50b20 be stripped and bored to 84mm with the correct length rods... thus essentially creating a m50b25?
Or are there significant differences between the two blocks or heads that would limit the usage? I know the inlet manifold and some ancillaries may be different. But those can all be sorted separately.
Any advice would be great.
Thanks :banana:
Post Fri Aug 30, 2019 9:22 am
Ive sold several M50B20 cast iron blocks to people who were going to bore them out, ive no idea how they got on though.
Flaffy1991
Post Sat Aug 31, 2019 4:03 pm
Do you know of any differences between the blocks themselves?
I can’t find any information anywhere on the matter.
Post Sun Sep 01, 2019 7:45 pm
Ive never looked that close to be honest, I do know that the crank journals are exactly the same and the heads will physically bolt down as ive bolted a 2.0 head to a 2.5 before but only to test fit. If you bought both head gaskets you would soon see if there were any differences in water/oil ways, I would be very surprised if there were
