Coolant Vacuum Bleeder - Thoughts??
BristolE30
Post Thu Jun 13, 2019 11:14 am
Hey zone,
As some of you may have noticed I've been having problems with bleeding my M10 cooling system/heater problems. I want to completely rule out an airlock so I figured I'd buy one of those Ebay vacuum bleeders. They look extremely simple, and then at least I'll know airlock is not an issue (could be heater valve, matrix etc).
https://www.ebay.co.uk/itm/Universal-Co ... %7Ciid%3A1
What does everyone think of them, anyone used one? My only concern is could it damage the Thermostat? Applying a vacuum to the system.
Appreciate any thoughts,
Jo
BMW E30 316 ‘87
BMW E30 325i ‘88 :bmw:
Bristol, UK
arrisbmw
Post Thu Jun 13, 2019 3:08 pm
I would follow Brians advice on bleeding , which can be a pig on a 6 pot and if no heat coming from the heater after 2 mins can crack the back of head around no 6 pot. /www.e30zone.net/forum/viewtopic.php?f=2 ... m#p2058239
HJ1981
Post Thu Jun 13, 2019 5:56 pm
If that link does not help you, you can consider the hand pump/coolant system testing kit thing they got at your local parts store.
BristolE30
Post Thu Jun 13, 2019 11:05 pm
HJ1981 wrote: ↑
Yes the link I believe only really helps with the M20 engines that have bleed screws. The M10 system has none, and is completely reliant on you being able to massage out the airlocks. Seems a bit to risky for me...
Will try the vacuum kit!
BMW E30 316 ‘87
Bristol, UK
BristolE30
Post Thu Jun 13, 2019 11:07 pm
Also I’m not getting any over heating so I think it’s safe to say not much risk of head cracking. I hope so anyway!
BMW E30 316 ‘87
Bristol, UK
aimlessrock
Post Fri Jun 14, 2019 9:07 am
Just seen your PM=-that looks just like mine, they are very reasonable and saves lots of hassle (i have an M20)
E30 320i Convertible (1989)
190 Mercedes (1988)
