Fog light teltail light
yetta
How do I gain access to the fog light teltail indicator to change the bulb in it ?
BenHar
Have a read through this page in the wiki: https://www.e30zone.net/e30wiki/index.p ... nstruments
Ben
Ben
As you can see from the removal instructions in the link above, it's easy enough to remove the cluster, but, depending on the size of your hands and/or your dexterity with a pair of needle nosed pliers, it's possible to change some of the lamps in the row from underneath, after just removing the under dash panel.
yetta
all fixed and a great link thanks
