Clutch Master Cylinder RHD Removal?
MyNameIsOllie
Post Sat Mar 30, 2019 3:34 pm
Hi everyone,
I'm trying to replace my clutch cylinders, however I'm stuck on removing the master as it will not move.
I have removed all relevant nuts and bolts, disconnecting the hard line and cutting the soft line to the reservoir (I'm replacing this anyway) - however the bastard won't budge. The grommets in the firewall for the end of the cylinder and the soft line seem to be prohibiting its movement.
Does anyone have any wisdom with removing the master on a right hand drive model? I have not been able to find any guides on how to do this on a UK car.
Thanks so much.
steve_k
Post Sat Mar 30, 2019 7:05 pm
i did mine the other day,
it should just pull out nice & easy if you wiggle it about a bit while pulling on it,
see if you can remove the firewall grommet as that may help.
MyNameIsOllie
Post Sun Mar 31, 2019 8:37 pm
steve_k wrote: ↑
Thanks dude, pried that sucker out and it worked a trick.
steve_k
Post Sun Mar 31, 2019 10:42 pm
MyNameIsOllie wrote: ↑
steve_k wrote: ↑
thought it might, it can be an arse to get back in though.
