Missing ICV
Bodwan
Hi bungling amature here , I've just bought a E30 320i. It doesn't idle properly when warm, so after some googling I decided to try to clean the ICV. Having spent about an hour looking for the thing in the engine bay, I have had to conclude that's it's not there.
Can anyone point me in the right direction? Were there e30's without ICVs? Where should it go if I buy a new one?
All the diagrams I can see for the M20 engines have it coming of the boot between the air-intake and the throttle body. The haynes manual only has diagrams of the M10 engine so not much help. Am at a loss.
Here is a pic of where i believe it should be -
http://anew.design/FTP/IMG_20180810_170225.jpg
(yes I know, I have a new boot coming this week)
Thank you,
Tim
Thank you,
Tim
arrisbmw
can,t see the image. sorry
Bodwan
Sorry, tagged it as a URL, should work now
arrisbmw
http://www.verrill.com/car/idle/e30_idleproblem.shtml
should be there . unless someone done a icv delete.
Bodwan
That's what I thought. Although I've just ordered a new intake boot, specifically for a pre '87 model. And it only seems to have 1 outlet.
https://www.mecatechnic.com/en-GB/air-f ... C44035.htm
The image in the Ted's house article shows 2 outlets on the boot.
Is it possible that pre-'87 m20's didn't have ICVs ???
arrisbmw
i assume m20 with fuel injection ?, what year ?
Bodwan
yeah it's fuel injection, from '85
arrisbmw
https://www.google.co.uk/search?safe=st ... PQZWAytS7M:
think your is like this as its an ealier car pre- facelift
arrisbmw
see the black rubber pipe on right hand side top of photo going under the inlet manifold, where does that go , chase it back.
could be on the end of that. one done up with a jubilee clip.
arrisbmw
look at this at 40 seconds icv. he pulls a connector off it.
Bodwan
Yes! it's identical. Thank you I thought I was going mad.
The hose that goes under the manifold ends at the rocker cover.
Could it be this thing??
http://anew.design/FTP/IMG_20180813_175148.jpg
arrisbmw
on the left.
it is the other side of engine from your photo. got it yet
arrisbmw
NO NOT THATBodwan wrote:Yes! it's identical. Thank you I thought I was going mad.
Bodwan
This is what that section of the engine looks like on my car. ICV suspiciously absent. Maybe you're right and somone's deleted it.
http://anew.design/FTP/IMG_20180813_180117.jpg
http://anew.design/FTP/IMG_20180813_180102.jpg
arrisbmw
I THINK IT SHOULD BE HERE
PAUSE IT AT 39 SECONDS
arrisbmw
YES SOMETHING IS MISSING ON YOURS.
Bodwan
taquinvol
That is called the intake manifold connection flange:
https://www.realoem.com/bmw/enUS/showpa ... 1611708857
On that note, I wish I could find someone to tell me how the screw found on it is properly adjusted:
http://www.e30zone.net/modules.php?name ... c&t=276621
arrisbmw
https://www.realoem.com/bmw/enUS/showpa ... Id=13_0597
i think this is how yours should be with a rubber pipe over / under the inlet manifold connecting 5 icv to 8 the rubber boot.
arrisbmw
also you may have a 2 pin connector loose over the drivers side on top of engine.
on your 2 nd http://anew.design/FTP/IMG_20180813_180102.jpg
image thats where the icv should be.
look at the youtube i posted. between 30 - 45 seconds
hope that helps.
hope that helps.
Bodwan
The ICV should be on the hose between the rubber boot and the "intake manifold connection flange", connected to the hose entering from the top?
I think I found the cable that connects to it, and I have ordered a new ICV online so we'll see!
Thank you very much for your help, was feeling a bit hopeless!
