Missing ICV
Bodwan
Post Mon Aug 13, 2018 4:59 pm
Hi bungling amature here , I've just bought a E30 320i. It doesn't idle properly when warm, so after some googling I decided to try to clean the ICV. Having spent about an hour looking for the thing in the engine bay, I have had to conclude that's it's not there.
Can anyone point me in the right direction? Were there e30's without ICVs? Where should it go if I buy a new one?
All the diagrams I can see for the M20 engines have it coming of the boot between the air-intake and the throttle body. The haynes manual only has diagrams of the M10 engine so not much help. Am at a loss.
Here is a pic of where i believe it should be -
http://anew.design/FTP/IMG_20180810_170225.jpg
(yes I know, I have a new boot coming this week)
Thank you,
Tim
arrisbmw
Post Mon Aug 13, 2018 5:08 pm
can,t see the image. sorry
Bodwan
Post Mon Aug 13, 2018 5:10 pm
Sorry, tagged it as a URL, should work now
arrisbmw
Post Mon Aug 13, 2018 5:11 pm
http://www.verrill.com/car/idle/e30_idleproblem.shtml
should be there . unless someone done a icv delete.
Bodwan
Post Mon Aug 13, 2018 5:22 pm
That's what I thought. Although I've just ordered a new intake boot, specifically for a pre '87 model. And it only seems to have 1 outlet.
https://www.mecatechnic.com/en-GB/air-f ... C44035.htm
The image in the Ted's house article shows 2 outlets on the boot.
Is it possible that pre-'87 m20's didn't have ICVs ???
arrisbmw
Post Mon Aug 13, 2018 5:23 pm
i assume m20 with fuel injection ?, what year ?
Bodwan
Post Mon Aug 13, 2018 5:24 pm
yeah it's fuel injection, from '85
arrisbmw
Post Mon Aug 13, 2018 5:38 pm
https://www.google.co.uk/search?safe=st ... PQZWAytS7M:
think your is like this as its an ealier car pre- facelift
arrisbmw
Post Mon Aug 13, 2018 5:42 pm
see the black rubber pipe on right hand side top of photo going under the inlet manifold, where does that go , chase it back.
could be on the end of that. one done up with a jubilee clip.
arrisbmw
Post Mon Aug 13, 2018 5:57 pm
look at this at 40 seconds icv. he pulls a connector off it.
Bodwan
Post Mon Aug 13, 2018 5:59 pm
Yes! it's identical. Thank you I thought I was going mad.
The hose that goes under the manifold ends at the rocker cover.
Could it be this thing??
http://anew.design/FTP/IMG_20180813_175148.jpg
arrisbmw
no sorry 25 sec
arrisbmw
Post Mon Aug 13, 2018 6:02 pm
on the left.
it is the other side of engine from your photo. got it yet
arrisbmw
Post Mon Aug 13, 2018 6:09 pm
Bodwan wrote:Yes! it's identical. Thank you I thought I was going mad.
NO NOT THAT
Bodwan
Post Mon Aug 13, 2018 6:10 pm
This is what that section of the engine looks like on my car. ICV suspiciously absent. Maybe you're right and somone's deleted it.
http://anew.design/FTP/IMG_20180813_180117.jpg
http://anew.design/FTP/IMG_20180813_180102.jpg
arrisbmw
Post Mon Aug 13, 2018 6:20 pm
I THINK IT SHOULD BE HERE
PAUSE IT AT 39 SECONDS
arrisbmw
Post Mon Aug 13, 2018 6:24 pm
YES SOMETHING IS MISSING ON YOURS.
Bodwan
Post Mon Aug 13, 2018 6:32 pm
Ok, thanks for your help!
Bodwan
Post Mon Aug 13, 2018 7:31 pm
Can anyone else shed any light on what this part is?
taquinvol
Post Mon Aug 13, 2018 8:07 pm
That is called the intake manifold connection flange:
https://www.realoem.com/bmw/enUS/showpa ... 1611708857
On that note, I wish I could find someone to tell me how the screw found on it is properly adjusted:
http://www.e30zone.net/modules.php?name ... c&t=276621
arrisbmw
Post Tue Aug 14, 2018 9:55 am
https://www.realoem.com/bmw/enUS/showpa ... Id=13_0597
i think this is how yours should be with a rubber pipe over / under the inlet manifold connecting 5 icv to 8 the rubber boot.
arrisbmw
Post Tue Aug 14, 2018 10:03 am
also you may have a 2 pin connector loose over the drivers side on top of engine.
on your 2 nd http://anew.design/FTP/IMG_20180813_180102.jpg
image thats where the icv should be.
look at the youtube i posted. between 30 - 45 seconds
hope that helps.
Bodwan
Post Tue Aug 14, 2018 2:22 pm
The ICV should be on the hose between the rubber boot and the "intake manifold connection flange", connected to the hose entering from the top?
I think I found the cable that connects to it, and I have ordered a new ICV online so we'll see!
Thank you very much for your help, was feeling a bit hopeless!
