Hey zone
My top coolent pipes burst the other day fitted it and sorted the coolent ran the fans was warm so was happy.
Today it really overheated and the fans blew cold. I removed the bleed screw and mostly coolant came out but my header tank is guessing water out of the top have I got a big air lock that's just came through? Any help would be much appreciated.
Coolent issues
SeanOB
I don't know if this is overkill, but I usually add coolant to the hoses themselves first to get rid of as much air as possible. Did you get the front end up gradient, or better yet up on jack stands after? Really helps to get any air up to that bleed screw.
1991 325i SE sedan
paultv
When you bleed, make sure the heater system is on full hot, loads of air could be trapped causing air lock, just a heads up.
Paul
Paul
aimlessrock
m20?
E30 320i Convertible (1989)
190 Mercedes (1988)
190 Mercedes (1988)
MiniC
Yeah also thanks for all the help guys!
Satan
As above and squeeze the top hose to help circulate the coolant.
aimlessrock
elevation, coolant in the hoses help but i would invest in a vacuum bleeder- saves a lot of hassle.
190 Mercedes (1988)
190 Mercedes (1988)
MiniC
Alright thanks guys. My altinator belt was rough so changed that and ran the car to warm it up before bleeding. It's now hot at the fans and I'm not getting any air through I'm confused!
arrisbmw
whatdo you mean not getting any air through
arrisbmw
there is a post on here telling you how to bleed 6 pot , by Brian moore iirc
