Clutch slipping while driving
pebisit
Post Wed Jun 20, 2018 10:51 pm
Hi, my Alpina 2.5 engages gear perfectly with no clutch slip whatsoever, but while in gear and driving has just started slipping for no reason
As mentioned, I can change gear and the clutch engages perfectly and only slips while I'm putting my foot down
Any idea what it could be???
Thanks in advance for any help
Satan
Post Wed Jun 20, 2018 11:49 pm
Clutch worn, whats the mileage and when was it last replaced?
I think the usual test is to pull the handbrake up put car in gear and try to pull away.
Post Thu Jun 21, 2018 2:32 pm
Satan wrote:Clutch worn, whats the mileage and when was it last replaced?
As above mate.
Drive to 30 mph and put your foot down when in top gear and if the clutch is worn the clucth will slip.
Some say that if you replace the whole of the clutch, then the slave and master cylindres are worth doing at the same time.
swin
Post Thu Jun 21, 2018 2:38 pm
I had the same problem in the past got a new clutch and when pulled out the gearbox it was soaked in fluid the slave cylinder was leaking clutch was fine :mad:
pebisit
Post Thu Jun 21, 2018 9:10 pm
Thanks for the info guys, its done 106k, 700 miles in the last 9 years since I've had it (yes that is 700!!!)
I'll get the clutch checked out, interesting comment re the slave cylinder
Satan
Post Fri Jun 22, 2018 7:53 am
pebisit wrote:Thanks for the info guys, its done 106k, 700 miles in the last 9 years since I've had it (yes that is 700!!!)
Lol, I think I did 940 in 14 months :o: :cry:
breihill01
Post Sun Jul 15, 2018 6:16 pm
Any oil leaks? I had sump gasket leaking into the bell housing and contaminated the clutch.
