325 in a 316
Jamiecowell
Post Sun Apr 01, 2018 3:16 pm
Hi all, new to the forum! I have a 1989 e30 316, I have been offered a 325 engine but I'm not sure what else I will need, will all the wiring work? I'm guessing I will need to change my box and diff? Any help would be appreciated! Cheers :)
Cloggy Saint
Post Sun Apr 01, 2018 3:28 pm
You'll need the engine and all ancillaries, wiring loom, ecu, gearbox/prop/diff, front suspension from an M20 to handle the extra weight. There's probably more that I've forgotten but that's enough to be going on with!
HartgeH27
Post Sun Apr 01, 2018 3:40 pm
Post Mon Apr 02, 2018 12:33 am
Don't forget to check out pin 20 on the C101 engine socket!
Cloggy Saint
Post Mon Apr 02, 2018 9:45 am
And the correct coding plug for the cluster.
Kedge
Post Thu Apr 05, 2018 2:24 pm
To add to the list, you'll also want the fuel pump and return lines, fuel filter and ideally the tank itself.
Here's the Zone thread - http://www.e30zone.net/modules.php?name ... highlight= 8)
Instagram - Kedge85
Post Thu Apr 05, 2018 6:18 pm
Kedge wrote:To add to the list, you'll also want the fuel pump and return lines, fuel filter and ideally the tank itself.
To convert a 316, he will, but the OP states a '89 316 which never existed, so I'm assuming he means 316i and not 316.
