Getrag input shaft bearing
Jamesy
Post Tue Jan 30, 2018 5:40 pm
Hi,
Does anyone know what's involved in replacing a getrag gearbox input shaft bearing (vehicle is a m40 1990 model)
Would this be a gearbox strip down job or is there a clever way of extracting the bearing with out pulling the gearbox apart.
I"ve had a bit look about on tInternet but can't seem to find much info on this particular task.
Thanks, Andrew.
Post Tue Jan 30, 2018 10:14 pm
AFAIK, it's quite an involved job.
For a bog standard M40 'box, it has to make more sense to source a good second hand replacement.
