Bottom part of the convertible wheel arch liners
Joedean
Post Wed Jan 24, 2018 8:53 pm
Hi all,Can anyone sell me the bottom parts of both wheel liner Splash guards? They come in to parts for the convertible and its the part that stops the water etc getting behind the wing next to the seal and doors,basicly behind the wheels.
Can't find anywhere.
Please help =-)
Satan
Post Wed Jan 24, 2018 10:34 pm
paultv
Post Thu Jan 25, 2018 1:08 pm
Looks like a big No.2 to me!
Paul :-)
Satan
Post Thu Jan 25, 2018 1:32 pm
paultv wrote:Looks like a big No.2 to me!
Paul :-)
Ooooh I remember those photos....... :mad:
Joedean
Post Thu Jan 25, 2018 5:48 pm
Easy,
whats with the number 2 gag?? don't get that one =-)
I believe that's a diagram foe an e30 not an e30 convertible.As you know the wing at the bottom is slightly longer on a convertible and there is another piece of plastic that wound join below around where that number 3 is on the diagram.
I've just got the number 2 joke now =-)
Satan
Post Thu Jan 25, 2018 11:15 pm
I put the details in to realoem for my car which is a 1988 convertible as you can see by the longer section on the wing.
The diagrams do not always line up,
BTW Number 1 If its Yellow Let It Mellow
And Number 2 If its Brown Let It Drown
Stick your details in to realoem and post up what you need.
Post Thu Jan 25, 2018 11:26 pm
i remember these little bastards , they're just an extension to any none cab front arch liner. the two cabs I've broke had separate parts at the bottom to fill the gaps left by standard arch liners .
Joedean
Post Thu Jan 25, 2018 11:34 pm
yeah you know what I'm saying Magpie they are imposible to find and I didn't know they existed until I rotted out a wing and wondered why. The other wing is starting to go now as the water gets behind without that bastard piece of plastic.
Hi satan,is Salome a site ?
don't get the yellow and brown references ?
Satan
Post Fri Jan 26, 2018 12:10 am
Joedean wrote:yeah you know what I'm saying Magpie they are imposible to find and I didn't know they existed until I rotted out a wing and wondered why. The other wing is starting to go now as the water gets behind without that bastard piece of plastic.
bloody spell check, meant realoem,
Satan
Post Fri Jan 26, 2018 12:12 am
I never noticed my car having an extra part to the arch liner apart from the part/flap you removed to clean out the gunk behind it.
Joedean
Post Fri Jan 26, 2018 7:50 am
Satan,think that's the bit i'm on about. I'll check out realoem then,thanks
paultv
Post Fri Jan 26, 2018 10:09 am
Part number 51711945867 and 51711945868 are for cabby, I fitted new ones as I had none - they fit all the way to the bottom of the arch - but no idea about additional short panel to adapt a non cabby liner.
Paul :-)
Post Fri Jan 26, 2018 10:16 am
The ETK (realOEM, etc.) diagram is the same, whether it's for the saloon or cab. The difference is that in the parts list under the diagram, there will be no reference to any cab. specific parts when looking at the list for a saloon.
The liner extensions are 51 71 1 943 829 and 830. As with all BMW parts, the odd numbered part is for the LH side, and the even number for the right.
Have you enquired with BMW (e.g. Cotswold in our traders' section) as to whether they are available new?
Joedean
Post Fri Jan 26, 2018 10:04 pm
Good work lads!!!
thanks for the part numbers,although ive just realized you've both given me different numbers =-) I'll look into that now
Joedean
Post Fri Jan 26, 2018 10:27 pm
Oh I think I see whats going on here.
Paulty your liners (part numbers) for the Cabrio are one piece and fit all the way round to the bottom of the arch down by the seal?? and Brian has give the part numbers for extension pieces that convert the standard liners to cover the inside of a convertible wheel arch??
Anyways I've put a post out in the Cotswold section!! cheers for that Brian
Post Fri Jan 26, 2018 10:38 pm
I think you'll find you need both pieces - the best way to use the ETK is to enter your VIN into the appropriate box, find the diagram (under bodywork), and look at the list below the diagram. All the parts listed with part numbers should be used on your car, unless a dealer option that was taken up changes things in that particular area.
Have you read HartgeH27's sticky in the Cotswold section?
I wouldn't be surprised if the larger, upper liner, is made from a cut down saloon liner, just as the outer steel wing is, although I haven't checked.
BenHar
Post Fri Jan 26, 2018 11:06 pm
Part number 10 on the diagram is what you are describing.
Ben
Joedean
Post Sat Jan 27, 2018 6:21 am
Hi ben,
yes now i'm looking at it in more detail it is piece 10!!!! It's funny as it looks like that is a piece from the front of the arch liner in that photo but that looks like the piece now that you say it =-)
