Ignition Problems
Octupusslime
Post Sat Nov 25, 2017 12:50 pm
Hi needed some advice on some ignition troubles. Got a 318i 1991. Just recently the car has become hard to start the key turns fine and releases the steering lock no problems. However it won't start unless the key is turned as far as it will go and held with some force. I am thinking the ignition barrel or switch have worn out? What might be the problem and is it a simple fix? Thanks in advance.
Bazo187
Post Sat Nov 25, 2017 1:41 pm
I got the same problem. mines been sat for nearly a year now and the roofs been leaking I think its moister that's caused it.
Post Sat Nov 25, 2017 1:52 pm
It will be wear in the plastic switch clipped to the back of the ignition/lock barrel. Metal blade on the back of the barrel engages with a plastic slot in the switch. Metal blade wins.
paultv
Post Sun Nov 26, 2017 11:52 am
Exactly what happened to mine, easy to replace it as the switch simply clips on the back of the barrel.
Paul :-)
Octupusslime
Post Sun Nov 26, 2017 10:19 pm
Thanks will pickup a new switch from Cotswolds before it gets worse.
cjones
Post Fri Aug 24, 2018 6:15 pm
I have a RHD car from the UK in the states, and I need to replace the ignition switch.
Does anyone have experience on whether it's the same switch as all other e30s?
My mechanic says it needs to be ordered from a dealer in the UK.
Satan
Post Fri Aug 24, 2018 7:02 pm
Speak to Cotswolds on here and see what options they come up with as the replacement barrel is ordered against the V5 Vin number I believe.
Satan
Post Fri Aug 24, 2018 7:03 pm
You could just remove it and start the car with a spoon.......
