any info on this part. please.
how to test ?
has anyone changed theirs. issue I got is a slight wobble at 70 mph.
its riveted together, can a replacement be used that is bolted together.
thanks
steering guibo , rubber coupling
Stefan on probation
I bought a unit from Dante and returned the old one to him, I think there is an upgraded one form elsewhere but I wanted to stay stock.
To test look at the rubber.
If you have a "slight" wobble at 70 then the wheels just need balancing.
As above, test by inspection. Original is riveted, but replacement is installed using special stepped bolts from BMW. See RealOEM or other online ETK.
arrisbmw
O.K thanks very much for prompt reply.
