steering guibo , rubber coupling
arrisbmw
Post Sun Oct 08, 2017 10:04 am
any info on this part. please.
how to test ?
has anyone changed theirs. issue I got is a slight wobble at 70 mph.
its riveted together, can a replacement be used that is bolted together.
thanks
Stefan on probation
Post Sun Oct 08, 2017 4:44 pm
I bought a unit from Dante and returned the old one to him, I think there is an upgraded one form elsewhere but I wanted to stay stock.
To test look at the rubber.
If you have a "slight" wobble at 70 then the wheels just need balancing.
Post Sun Oct 08, 2017 4:59 pm
As above, test by inspection. Original is riveted, but replacement is installed using special stepped bolts from BMW. See RealOEM or other online ETK.
arrisbmw
Post Mon Oct 09, 2017 12:18 am
O.K thanks very much for prompt reply.
