wont start after stalling
kev76
Post Mon Sep 11, 2017 7:48 am
Morning folks . M20 started fine but I stalled it after about 30 seconds then took a life time to start. Often struggles to start if I leave it for 10 mins if I pop in a shop say. I'm thinking blue temp sensor.. Do you think I'm on the right track of barking up the wrong tree .cheers guys .[/code]
Post Mon Sep 11, 2017 9:41 am
What age/model is the car?
Yes, testing the blue sensor at the ECU socket is a good starting point to check.
Post Mon Sep 11, 2017 10:24 am
Speedtouch wrote:What age/model is the car?
Yes, testing the blue sensor AT THE ECU SOCKET is a good starting point to check.
kev76
Post Mon Sep 11, 2017 11:47 am
H reg 320i.
arrisbmw
Post Mon Sep 11, 2017 1:30 pm
I,m trying to understand the temp sensors on my e30. looks like there are 2, one is blue , what the difference and how should i test the actual sensors them self ?
thanks
Post Mon Sep 11, 2017 1:56 pm
arrisbmw
Post Mon Sep 11, 2017 5:57 pm
cheers. sounds like its worth check every now and then.
Post Mon Sep 11, 2017 6:39 pm
kev76 wrote:H reg 320i.
This is a post facelift car, so will have the notorious plug and socket under the inlet manifold that the blue temp. sensor signal passes through. If the sensor fails the resistance tests AT THE ECU SOCKET, then the problem is far more likely to be with the plug and socket mentioned above than with the sensor itself
chainslack
Post Sun Sep 17, 2017 3:48 pm
+1 for this : Same problem, same symptoms - Fixed mine by removing the multiway connector under the inlet manifold; draining the murky water that had collected; cutting out the wires and resoldering them.
