Purple tag rack m20
Nickerz
Wed Sep 06, 2017 10:00 am
What engine mounts have people used when fitting e46 rack to 325i m20 standard exhaust as dan has said different mounts are needed for his conversion.
TriggerFish
Thu Sep 07, 2017 10:34 am
Standard (brand new) mounts, standard exhaust manifold, and standard steering linkage with guibo works perfectly for my M20, I'm happy to say!
I did have photos, until... photobucket...
panose30sg
Thu Sep 07, 2017 4:44 pm
Standard steering linkage dosnt work
You need a hybrid e36 with e30 steering linkage
Also you need e46 inner tie rods and e36 outer tie rods
Mounts and exhaust its not a problem
e30 forever
tha881
Thu Sep 07, 2017 5:13 pm
Standard linkage worked with mine, but the guibo had to be removed
TriggerFish
Thu Sep 07, 2017 9:00 pm
http://i660.photobucket.com/albums/uu32 ... 212351.jpg
I can't embed the image, but there's the 067 rack, with the standard linkage, with the guibo, clearing the standard manifold on an engine on standard mounts. (Obvs. not in the final state of fitment there with those bolts!)
jmc330i
Thu Sep 07, 2017 10:16 pm
TriggerFish wrote:http://i660.photobucket.com/albums/uu32 ... 212351.jpg
When I tried the E30 linkage complete with guibo, the splined shaft poked through the linkage enough to contact the UJ while turning, which is far from ideal and one reason a shorter linkage should be used.
James
'91 325i Sport
'93 318i touring 16v
Sanchez
Thu Sep 07, 2017 11:31 pm
Mine is
Standard linkage minus rubber guibo.
Linkage width shaved on bottom Union.
Scorpion down pipes.
E30 inner and outer track rods.
BenHar
Fri Sep 08, 2017 10:16 am
Photobucket has hijacked you account so we can't see that.
Any chance you could put it on a differnt hosting site, as I think a lot of people here would like to see it.
Ben
jmc330i
Fri Sep 08, 2017 11:59 am
Ben
You can click the link and view it.
And the splined shaft does indeed look close to the UJ.
James
'91 325i Sport
TriggerFish
Fri Sep 08, 2017 2:19 pm
Yeah, it is close, but I've checked, and it doesn't contact at all, so I'm happy with it. If there were any contact, I'd have reconsidered my linkage choice. I wonder if mine upper joint was closer to the bulkhead than yours, giving a little more clearance?
Here's an embedded version, for reference.
