Wiper speed
kev76
Post Thu Aug 31, 2017 10:12 pm
Hi guys .
Hows your wiper speed mines not so good . There seems to be hardly any difference between normal and fast . Is this normal or could it be motor or stalk . Cheers
brutus
Post Thu Aug 31, 2017 10:28 pm
yes could be either ,,,,
MANY e30 PARTS FOR SALE.
( all models available )
318i baur 1986 auto.
maxfield
Post Thu Aug 31, 2017 10:57 pm
Have a look in the Wiki, there is a guide on stripping the motor down and greasing it. That would be my first port of call.
kev76
Post Thu Aug 31, 2017 11:12 pm
Cheers guys . Ive had the motor stripped as per wiki as the wipers weren't parking correctly. Could of damaged it then maybe . I have both parts just didnt want to waste time on it if thats just the way it is
biffer
Post Fri Sep 01, 2017 12:03 am
Top-speed on my car noticeably faster than normal-speed-if it's not the motor then try squirting WD40 or similar into the two wiper-arm pivots/bushes where they emerge from the scuttle-panel,these could be starting to semi-seize after years of use.
if this does speeds things up,then for a perm. fix i put a few drops of engine-oil into the pivots-is this acceptable or are there rubber-seals in there that will be jinxed by the oil?
Contours
Post Fri Sep 01, 2017 1:50 am
I recall buying a brand new motor direct from the BMW classic shop about 3 years ago for 80 euros with free delivery. At this price it is hardly worth cleaning up a 28 year old motor or messing with second hand ones. The wiper speed change was dramatic. You could use a silicone based lubricant on the pivot points rather than oil. You may hear a squeaking from them if they are straining.
