24 valve conversion e34 engine & box
YLO25
Post Wed Mar 15, 2017 8:29 am
Hi
can someone please advise i have read the link for the M50 M52 engine swaps i noticed it says you can use the engine from the E38's can the E34 525i engine & box from a Nreg touring be used.
many thanks
Post Wed Mar 15, 2017 10:01 am
E34 525i touring or saloon engine and box will fit, and are worth buying at the right price just for the sump, oil pick up and inlet manifold alone, even if you subsequently fit a M52B28. These three items alone are worth a few hundred pounds these days.
YLO25
Post Wed Mar 15, 2017 10:29 am
Great.
Thank you.
Post Wed Mar 15, 2017 11:34 am
Be aware that early E34 525is were fitted with the old M20B25 engine, the same as fitted to E30s.
Post Wed Mar 15, 2017 12:32 pm
An N-reg (1994-96) E34 525i should have the M50/52 engine.
