Cabriolet wings, genuine or aftermarket?
Post Thu Feb 23, 2017 9:33 pm
As title, has anybody bought new cabby wings recently and if so where from? What was the quality like? Im looking to buy the best fitting wings and a bit of advice would be much appreciated 8)
Topblag
Post Thu Feb 23, 2017 9:54 pm
You can only get them from BMW AFAIK.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
dave525
Post Fri Feb 24, 2017 11:24 am
Isnt the lower section a separate piece welded on,maybe you could get good saloon ones and re use the cab lower section
brutus
Post Fri Feb 24, 2017 1:35 pm
if yr able to do that, then yes !
MANY e30 PARTS FOR SALE.
( all models available )
318i baur 1986 auto.
Topblag
Post Sat Feb 25, 2017 11:01 am
dave525 wrote:Isnt the lower section a separate piece welded on,maybe you could get good saloon ones and re use the cab lower section
The wings come as one piece and I think they are manufactured that way. You can make and weld on the bottom section, as that is where they rot.
Post Sat Feb 25, 2017 2:54 pm
Original E30 cab. wings are definitely manufactured in two pieces. The larger piece is identical to a saloon wing with a section chopped off, and the smaller section is an extended version of the missing piece. As said earlier in the thread, a saloon wing can be cut, and the cab. lower piece welded on, if you have a serviceable piece, or it's not difficult to fabricate a fairly close copy.
The weld is hidden behind a trim piece, so no great welding skills are required. Pop rivets or small nuts and bolts could be used at a push.
Post Sun Feb 26, 2017 4:44 pm
Decided on saloon wings with an extra piece welded in to lengthen them, the originals are in self destruct mode at the bottoms :D
